16 years agoAssigning LVDS (differential) pins
I am using a Cyclone III device with LVDS inputs and outputs in bank 2 and 5.
My usual design capture method is to use a *.bdf block diagram/schematic file for the top level. Here I show all of the assigned input and output pins. I go to the pin assignment tool to assign the pins. ?What is the proper procedure for assigning pins to differential I/O? I have taken a couple different approaches 1. using alt_outbuf_diff symbols 2. inserting a single output symbol for which the fitter assigns the complement pin itself. 3. assigning both the signal and signal(n) pins in the assignment editor. What is the proper way to assign differential pins?
