13 years ago
Assigning individual bits
Hi all,
I'm a complete newbie in Verilog, so I have a question.
I have in my main Verilog file (irrelevant code stripped out):
//  This code is generated by Terasic System Builder
module Lab2(
    //////////// SEG7 //////////
    HEX0,
    HEX1,
    HEX2,
    HEX3,
    HEX4,
    HEX5,
    HEX6,
    HEX7
output                     HEX0;
output                     HEX1;
output                     HEX2;
output                     HEX3;
output                     HEX4;
output                     HEX5;
output                     HEX6;
output                     HEX7;
    Default u0 (
        .id7seg_display_export        (???)
endmodule
Now, Default.id7seg_display_export is declared as:
output wire  id7seg_display_export  // id7seg_display.export
My question is, how do I connect individual bits from id7seg_display_export to the different HEX outputs signals? I just can't figure it out because I don't know the syntax...
    That's very simple. Some examples:
    assign HEX0 = id7seg_display_export[6:0];
    assign HEX1 = id7seg_display_export[13:7];
    assign HEX2[0] = id7seg_display_export[3];
    assign HEX2[4:1] = id7seg_display_export[12:9];
    assign HEX2[6:5] = id7seg_display_export[20:19];
    The last 3 above could even be companded into a single one:
    assign HEX1[6:0] = { id7seg_display_export[20:19], id7seg_display_export[12:9], id7seg_display_export[3]};
    Are you sure that works?
    For doing
    I get that id7seg_display_export is undefined. Slapping in uc, as in:
    assign HEX2[0] = uc.id7seg_display_export[3];
    gives another error, something like cannot resolve assign id7seg_display_export (dunno if this is right anyway).
    BUT, I managed to get it working by using (yes, I changed the name):
    .seg7_display_export ({HEX3, HEX2, HEX1, HEX0})
    Sorry, You are right.
    I didn't notice that id7seg_display_export is actually the name of the submodule port.
    I treated it like a common signal
    I mean, what I wrote should apply in this case, where the same name is defined for the top level signals
    wire [27:0] id7seg_display_export;
    Default u0 (
    .id7seg_display_export(id7seg_display_export)
