ThomasTessier
3 years agoArria5 GX Transceiver Clocking Question, using internal clock on more than 4 transceivers?
Support,
I have a design which is working with 4 transceivers and each transceiver is treated independently from the standpoint of our HDL design. The transceivers are driven on the pins: rx_cdr_r...
ThomasTessier
3 years agoDevice: 5AGXFB3H4F35C4
OS: Linux CentOS 7
Tool Version: QuartusPrime 21.1.0.842
This is a development card so the only transceiver pins I can use are as follows:
G3, J3, L3, N3, R3, U3, W3, AA3 -- TX_P
H1, K1, M1, P1, T1, V1, Y1, AB1 -- RX_B
The clock is internally generated, yes I know the Jitter will be higher but that is what I have available. This design uses a home grown protocol so we just need the Transceivers for SERDES operation, we are bypassing much of the logic. I have this working with 4 transceivers but now need to expand to 6 transceivers. That is where the issue resides.
TomT...
