11 years agoHi,
I have sent a similar question to Altera Support team and received an answer from the CMU support group. " transceivers consumes one additional transceiver as CMU." 1) a x8 bonded transceiver attempts to put the CMU in the middle transceivers ( total 9 transceivers) 2) a x4 bonded transceiver attempts to put the CMU in the beginning transceivers. ( total of 5 transceivers) 3) a single transceiver uses one additional transceiver as CMU. (total of 2 transceivers) for system planning purposes, 1) single transceiver implementation use 200% as many transceivers as expected 2) quad transceiver implementation use 125% as many transceivers as expected 3) Octal transceiver implementation use 112% as many transceivers as expected 4) the pin assignments of the DK-START-5agxb3n preclude using all of the available serdes as transceivers. An excellent example of QUAD transceiver implementation is the PCI-e x4 megawizzard. An excellent example of OCTAL transceiver implementation is the PCI-e x8 megawizzard.
