MKark1
7 years agoArria 10 SoC Serdes Error
Hi, I am in the early stages of my design working on Schematic verification. I am working on Arria 10 SoC 10AS066K2F40E1HG in Quartus Prime Pro 17.1 my design contains a high speed ADC which gives ...
IDeyn
Contributor
7 years agoHi MKark1!
I'm unable to inspect your updated project at this week - I'm not at home.
So first of all it is great that you were able to solve the error.
I will return and see our project.
As about your new questions.
I suppose that one bank could support more than 1 SERDES, but I need to check your particular case.
As about mapping a clock to non-dedicated clokc pin - it is a bad idea and you better avoid doing this,
in that case SERDES IP couldn't be able to use PLL to compensate for a phase difference between clock and data.
Ivan
