MKark1
7 years agoArria 10 SoC Serdes Error
Hi, I am in the early stages of my design working on Schematic verification. I am working on Arria 10 SoC 10AS066K2F40E1HG in Quartus Prime Pro 17.1 my design contains a high speed ADC which gives ...
IDeyn
Contributor
7 years agoHi MKark1!
After brief look at your project, I can say that you need to change SERDES factor to 8, because your ADC is 16-bit wide. Update - you need to change that in ... LVDS_example_IP_name ...
For further work, you'd check this video - https://www.youtube.com/watch?v=02lgfcxSjQA
Of course, this video explains 14-bit case, in your case you need 16-bit.
And as about connection of differential ports - I think you could directly connect input P pin to ALTLVDS SERDES without any issues.
Ivan
