MKark1
7 years agoArria 10 SoC Serdes Error
Hi, I am in the early stages of my design working on Schematic verification. I am working on Arria 10 SoC 10AS066K2F40E1HG in Quartus Prime Pro 17.1 my design contains a high speed ADC which gives ...
MKark1
7 years agoHi @IDeyn ,
The outputs of my ADC (partno: ADS42LB69) are differential. the template instantiation in VHDL requires std_logic_vector as input where each bit corresponds to 1 bit (P and N together make 1 bit, correct me if I am wrong). So I couldn't find a way to directly connect differential pins of the ADC to the SERDES IP. Hence, I have used Alt_INBUF_DIFF.
Also, regarding clock, I am feeding the output clock from the ADC to the SERDES IP. My design fails in the synthesis stage itself. So I believe the issue is in the code somewhere rather than pin assignment. anyways, you can still check the pin planner, assigned pins are clock capable.
Have a look at my attached project.
Thanks in Advance.
Mihir
