10 years agoArria 10 OpenCL BSP Linux source build question
HI everyone I got arria 10 OpenCL BSP for 15.1 from FAE,and I tried to compile official source code but have error message as below lib/libpkg_editor.a(pkg_editor.o): In function `add...
10 years agoCheck if libelf is on your ld_library_path. Also, you should have the .a for the elf library. That would be a start. I had similar issues with a CycloneV, but don't have access to it right now. I can look up the details for a cmake file if the above do not work.
