corestar
Contributor
5 years agoArria 10 Native Floating Point Adder Issue
I'm using Quartus 19.1 Standard and there is an odd issue with the native Arria 10 floating point adder. As shown in the attached, the Ax input has a latency of 3 clocks but the Ay of only two. So th...
- 5 years ago
You can actually click on that register from the Native DSP Block floating Point GUI to change the clock source and also disable that register if this is not required.
Regards -SK
SengKok_L_Intel
5 years agoHi,
Regards -SK
- corestar5 years ago
Contributor
That worked! Thanks so much for the help. And I can reduce the multiplier latency, at the expense of Fmax, in the same way.
I'd suggest that removing that register might be a sensible default for an adder.
