Arria 10: Linux Kernel Configuration
Hello ,
I am designing linux OS for our custom board which took reference from Arria 10 SoC. While building u-boot , I did changes in qsys for all the hardware modification at HPS side , so that a .sof file is generated which build a uboot_mkpimage.bin .
But I am confused with the kernel configuration , I took reference from https://rocketboards.org/foswiki/Documentation/A10GSRDGeneratingTheLinuxDeviceTreeLTS
which indicated that a dtb file is generated which is required to boot linux kernel.
This file is generated using sopcinfo and board xml files.
In order to boot the custom board , do we need to make any change in sopcinfo or board xml files , as we did in uboot build ?
If so ,how to modify xml files?
please do reply.
Priya
1 Reply
- EBERLAZARE_I_Intel
In my understanding, if the changes in Qsys have connections with the HPS it needs to be rebuild.
Have you check the HOWTO Create a Device Tree:
https://rocketboards.org/foswiki/Documentation/HOWTOCreateADeviceTree
There are sections for Arria 10 SoC, I recommend that you check it out.
