cconger
7 years agoArria 10 GX PLL not producing correct phase shift
I have generated an Altera PLL using Quartus Prime Standard Edition 17.1. The PLL accepts a 50 MHz reference clock, and produces five output clocks: 50 MHz, 200 MHz, 200 MHz w/ 1250ps shift, 333 MH...
JonWay_altera
7 years agoHi @CCong1
I am asked to look into your case and see if there is anything i can help out . May I know what does the fitter report says, does it show the correct phase shift?
Meanwhile, let me check the simulation with the 18.1 and Modelsim 10.5c. If the latest works fine, would you be able to check with the latest versions as well?
