niceflower
3 years agoArria 10 FPGA Fitter error 14566
The chip used is 10ax115RF40, and two instances of DDR4 are instantiated, using four banks: 2L, 2K, 3H, and 3G. I used the 2L and 2K DDR4 Fitter successfully, but another DDR4 with 3H and 3G had the ...
AdzimZM_Altera
3 years agoHi,
The IO Bank 2L,2K and IO Bank 3H,3G are not located in a same IO Column.
There is no connection in between the IO Columns.
Please choose the IO Banks that located in a same IO Columns if the interfaces are connecting to each other.
Adzim
- niceflower3 years ago
I know it.I am instantiating two DDR4 instances, one of which is successfully instantiated (2L, 2K) and the other is not successfully instantiated (3H, 3G), which is not ping-pong PHY.
