Arria 10 DSP resulta=(ay+az)*ax, resultb=(by+bz)*bx possible?
- SengKok_L_Intel
Yes, it is possible, you can use the Native Fixed-Point DSP Intel Arria 10 FGPA IP to configure it.
Resulta = (ay+az)* ax
Resultb = (by+bz)* bx
Regards -SK
- FPGAOLOG
According to Arria 10 DSP document, resultb is only available in m18×18_full operational mode, and in this mode's section it says the function is:
• resulta = ax * ay
• resultb = bx * byRegards,
Levent
- SengKok_L_Intel
You can also refer to section 3.2.2 pre-adder that stated it can configure in 2 independent 18 bits pre-adder. You may explore it from the " Pre-adder" tab in Native Fixed-Point DSP Intel Arria 10 FPGA IP.
- SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
