9 years agoArria 10 aocl diagnose failed
Dear all, I have used an Arria 10 board on Ubuntu 12.04 OS. And I successfully flash the board with OpenCL hello_world image. After reboot the PC and type lspci | grep altera, I get: 01:00.0 ...
9 years agoYou might be onto something but the driver seems to be loading anyway, or else the "Kernel modules" field from lspci should be empty. I did some searching, it seems to avoid that issue, you either have to recompile your OS kernel with driver signature verification disabled, or get Terasic to sign that driver for you. Take a look here (http://stackoverflow.com/questions/24975377/kvm-module-verification-failed-signature-and-or-required-key-missing-taintin) for more info. As a last resort, you can try CentOS 6.x, I am pretty sure there is no signature verification on CentOS 6.
