9 years agoArria 10 aocl diagnose failed
Dear all, I have used an Arria 10 board on Ubuntu 12.04 OS. And I successfully flash the board with OpenCL hello_world image. After reboot the PC and type lspci | grep altera, I get: 01:00.0 ...
9 years agoThe driver is certainly working correctly then. I can think of more reason that it might not be working for you which I myself also encountered before. Since Terasic distributes their Linux BSP as a zip file which doesn't preserve file permissions, the diagnose script from the BSP might have incorrect permission and that is why it is giving this error. Try chmoding all the files inside the BSP_install_folder/linux64/libexec path to 755 and retrying the command. Better yet switch to root user temporarily, make sure the driver is loaded correctly also under the root user, and then running the diagnose command under that user.
