9 years agoArria 10 aocl diagnose failed
Dear all, I have used an Arria 10 board on Ubuntu 12.04 OS. And I successfully flash the board with OpenCL hello_world image. After reboot the PC and type lspci | grep altera, I get: 01:00.0 ...
9 years ago --- Quote Start --- Can you also try with -A 12 (or more) and see if you also have a "Kernel modules:" line? --- Quote End --- I have changed to CentOS but the same error happens and# lspci -v | grep -A 12 -i altera gives results: 01:00.0 Processing accelerators: Altera Corporation Device 2494 (rev 01) (prog-if 01) Subsystem: Altera Corporation Device 0002 Flags: bus master, fast devsel, latency 0, IRQ 16 Memory at e0d40000 (64-bit, prefetchable) Memory at e0d00000 (64-bit, prefetchable) Capabilities: [50] MSI: Enable- Count=1/4 Maskable- 64bit+ Capabilities: [78] Power Management version 3 Capabilities: [80] Express Endpoint, MSI 00 Capabilities: [100] Virtual Channel Capabilities: [200] Vendor Specific Information: ID=1172 Rev=0 Len=044 <?> Capabilities: [300]# 19 Kernel driver in use: aclpci_de5a_net_i2 Kernel modules: aclpci_de5a_net_i2_drv
