9 years agoArria 10 aocl diagnose failed
Dear all, I have used an Arria 10 board on Ubuntu 12.04 OS. And I successfully flash the board with OpenCL hello_world image. After reboot the PC and type lspci | grep altera, I get: 01:00.0 ...
9 years agoAltera's PCI-E driver for OpenCL does not officially support Ubuntu; it only supports CentOS/RedHat and windows 7/8.1/10. It is quite likely that the PCI-E driver would not work on an Ubuntu machine even if it installs correctly. Still, try this command and see if the kernel module is actually loaded: sudo lspci -v | grep -A 10 -i altera
