11 years agoArray en VHDL
Hi everybody !
I want to add(xor) data with CD in shape array and the result would be S Can you help me correcting this code :library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cdm is
port (
clk : in std_logic ;
rst : in std_logic ;
data: in std_logic ;
odata: out std_logic ;
CD : in std_logic_vector(15 downto 0) ;
isis :out integer range 0 to 3 ;
S :out std_logic_vector(3 downto 0 ));
end entity ;
architecture beh of cdm is
type tab is array(3 downto 0)of std_logic_vector(15 downto 0);
signal i :integer range 0 to 3 ;
signal idata :std_logic ;
signal itab :tab ;
begin
code :process(clk,rst)
begin
if(rst='1')then
itab(i)<="0000" ;
else
if(clk'event and clk='1')then
itab(i)<= not(CD(15 downto 12)xor (data));
S(i)<=itab(i);
i<= i+1 ;
itab(i)<=not(CD (11 downto 8) xor(data));
S(i)<=itab(i);
i<=i+1 ;
itab(i)<=not( CD(7 downto 4) xor (data));
S(i)<=itab(i);
i<=i+1;
itab(i)<=not( CD(3 downto 0) xor (data));
S(i)<=itab(i);
i<=i+1 ;
if i=3 then
idata<=data ;
end if ;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
Thank you in advance for your answer
