Array data type conflicts with std_logic_vector definition.
I would like to use a arrays of standard logic vectors of two different lengths so I declare two new data types.
type tx_vector is array (0 to 14) of std_logic_vector(17 downto 0);
type rx_vector is array (0 to 14) of std_logic_vector(24 downto 0);
I then declare a signal using the tx_vector data type:
signal slave_com_tx_data : tx_vector;
But apparently this definition messes up the std_logic_vector definition? Later on in the code I have this line:
Iq_ref <= signed(std_logic_vector("000" & A_temp(7 downto 0)));
Where "A_temp" is declared as a simple std_logic_vector. The compiler throws these errors:
Error (10327): VHDL error at FCMLctrl.vhdl(868): can't determine definition of operator ""&"" -- found 5 possible definitions
Error (10647): VHDL type inferencing error at FCMLctrl.vhdl(868): type of expression is ambiguous - "rx_vector" or "tx_vector" are two possible matches
Error (10411): VHDL Type Conversion error at FCMLctrl.vhdl(868): can't determine type of object or expression near text or symbol "std_logic_vector"
Why does my declaration change the way simple std_logic_vectors operate?
I am using these libraries
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
Thank you for any assistance you may be able to provide.
- CBart19
It seems things work if I construct the arrays in two steps from std_logic elements.
type tx_vector is array (17 downto 0) of std_logic;
type rx_vector is array (25 downto 0) of std_logic;
type tx_array is array (natural range <>) of tx_vector;
type rx_array is array (natural range <>) of rx_vector;
I can then use the tx_array and rx_array.
Is there a reason for this?
This is not what I need. Ultimately, I need an array of std_logic_vectors.
- KennyT_altera
Which version of Quartus that you were using? Pro or std? Can you put your design.qar here so that I can look into the error? - RRomano001
Contributor
Hi CBart, just curios about:
Iq_Ref how and where is declared?
Rx Tx are different from.
What at lines 868 and few lines before 868 can fire there error.
Aggregate has 11 bit is Iq_ref a signed vector 11 bit long or in range?
If A_temp is an Std_logic vector why typecast aggregate of same type?
VHDL is strongly typed and rigid, also deterministic so I like that also if something require a lot of coding.
Try if this help clarify
http://www.bitweenie.com/listings/vhdl-type-conversion/
Roberto
- KennyT_altera
Hi Chris, Is there any update?
