13 years ago --- Quote Start --- as i said, the comparator only have 2 inputs --- Quote End --- My solution is still valid. For test1 you use one comparator to find max of A,B,C,D as follows: you assign A to a register then you update that register if B > A (one comparator with two inputs). then you update it again if C > B and again if D > C . You then move to test2, test3 It is up to you to use state machine per comparison or you can do it all in one lump of logic.
