11 years agoarithmetic mode for LE from vhdl
I have searched many threads for the solution and the answers were incomplete. So i try to do some investigation. this code in vhdl definitely put your counter in arithmetic mode for LE. if you ha...
11 years ago --- Quote Start --- It can only use the cin if count-en is generated on a LE in the same LE column so that it can put the signal on the carry chain, which I assume it isn't. Why do you use count en as the add word? This will just get converted to logic 1 because the register only enables the the input when enable is 1, hence you always add 1. --- Quote End --- okay. LE cin input accessable only by another LE. if i am wrong correct me. I don't know why quartus doesn't aware construction like cnt <= cnt +1 as signal to itself for turning on arithmetic mode at synthesis. So it was a tricky with code so quartus able to turn on arithmetic mode automatically. btw, any arithmetic operations with constant don't turn on arithmetic mode.
process(reset, clk, count_en)
variable v : unsigned(cnt_reg'length downto 0);
begin
if reset = '1' then
cnt_reg <= (others => '0');
cnt_full <= '0';
elsif rising_edge(clk) then
if count_en = '1' then
v := resize(cnt_reg, v'length) + (to_unsigned(0, cnt_reg'length) & count_en);
cnt_reg <= resize(v, cnt_reg'length);
cnt_full <= v(v'high);
end if;
end if;
end process;
