11 years agoarithmetic mode for LE from vhdl
I have searched many threads for the solution and the answers were incomplete. So i try to do some investigation. this code in vhdl definitely put your counter in arithmetic mode for LE. if you ha...
11 years agoIt can only use the cin if count-en is generated on a LE in the same LE column so that it can put the signal on the carry chain, which I assume it isn't.
Why do you use count en as the add word? This will just get converted to logic 1 because the register only enables the the input when enable is 1, hence you always add 1.
