11 years agoarithmetic mode for LE from vhdl
I have searched many threads for the solution and the answers were incomplete. So i try to do some investigation. this code in vhdl definitely put your counter in arithmetic mode for LE. if you ha...
11 years agoit seems that the very first LE do not use carry-in but it may . So the quetion is how to put a 'one' on the very first LE to cin input.
ps : the last element in counter (at msb) could run in arithmetic mode, but you should read the overflow counter value otherwise it run in normal mode.
