JCosp's avatar
JCosp
8 years ago
Are VHDL source code templates available in ModelSim IntelFPGA?
I have noticed that the option exists in standard ModelSim versions but I have not found it in IntelFPGA versions.
  • Hi,
    May I know what version of Modelsim you are referring to where VHDL code templates are available ?
    Per my knowledge there are some sample code available in Modelsim SE/ Modelsim Intel Edition stored in installation directory.
    <installation directory>\modelsim_ase\examples\tutorials\vhdl
    Arslan
  • Vicky1's avatar
    Vicky1
    I could not understand your question, Can you please tell, where did you find that option in standard ModelSim versions.
    Do you mean template available under "file -> New -> Source -> VHDL" in ModelSim Intel FPGA?
    Best Regards
    Vikas Jathar
  • JCosp's avatar
    JCosp
    I am using version 18.0 (IntelFPGA) which corresponds to version 10.5b from Mentor.
    I have checked the user's manual and I realized that in older versions (10.1) it says that you can open language templates by selecting 'Source→Show Language Templates' when the source window is open (User's Guide 10.1b page 465). However, I have not found an equivalent statement in the User's Guide for version 10.5b.
    Could have this option been removed in newer versions?
  • Hi,
    Yes I checked user manual for older version Source Window language template is removed starting Modelsim Version 10.3
    Modelsim User's manual page 47, "Table 1-8. Deprecated Features"
    Alternatively you can make use of Verilog/ VHDL language templates provided with Quartus Prime.
    Refer to user guide below on how to access them.
    https://www.intel.com/content/www/us/en/programmable/documentation/sbc1513987577203.html#mwh1409959570946
    Topic: Using Provided HDL Templates
    Arslan
  • bitwise's avatar
    bitwise
    ​There are still templates for VHDL/Verilog/SystemVerilog built into QuartusII.
    To use them, open a text editor window ("File/New" then select your HDL of choice) then either
    (a) Right-click in the text window and select "Insert Template",
    (b) Select "Edit / Insert Template" from the QuartusII menu, or
    (c) Left-click on the scroll icon that is in the text editor toolbar.
    These templates are for synthesis. If you want a test bench template then open your compiled project in QuartusII and select "Processing / Start / Start Test Bench Template Writer".
    Hope that helps.
    Craig
