10 years agoaocl diagnostic failed for no reason
Hello everyone, I am doing a project using Nallatech P385-A72. When I type "aocl diagnostic" command, the result shows: Verified that the kernel mode driver is installed on the host mac...
9 years agoI got the same error message because the DDR4 RAM (HILIO) is not fit properly on the board.
Once it is adjusted properly, aocl diagnose is passing. As I said earlier the other RTL designed I verified before doing these are not using DDR4, so they are working without any issue. Please check the DDR4 RAM on the board. Bhaskar
