10 years agoaocl diagnostic failed for no reason
Hello everyone, I am doing a project using Nallatech P385-A72. When I type "aocl diagnostic" command, the result shows: Verified that the kernel mode driver is installed on the host mac...
9 years agoHi yezhuoxi ,
Did you get any solution to the above problem? Can you share the solution as I am also facing the similar problem. Thank you Bhaskar
