9 years agoaocl diagnose failed : AAL issues
Hello
I am trying to run a .aocx file. when i do aocl diagnose , i get the following : aocl diagnose: Running diagnose from /home/saravind/bdw_fpga_pilot_opencl_v1.0/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec ccip_mmd.cpp:1003:serviceAllocateFailed() **Error : Failed to allocate Service ccip_mmd.cpp:1123:runtimeAllocateServiceFailed() **Error : Runtime AllocateService failed ccip_mmd.cpp:453:open() **Error : ALIAFU allocation failed Error: Failed to initialize the OpenCL/AAL system. Error: Ensure a correct OpenCL image is programmed on the FPGA, and that the CCI driver has been loaded. Using platform: Altera SDK for OpenCL CL device ID = 64 Failed clGetDeviceIDs. Error code: -1 aocl diagnose: failed. I think this issue is due to some library environment variable settings. Please let me know if you know of any possible reasons/solutions to this issue. Thank you.1 Reply
Your board must come with a "getting started guide" that comes with step by step instructions as to how you should set up your board. Make sure you carefully read and follow the instructions.
