11 years agoI finally found the files you're referencing. I've never messed with those and don't recommend you to either. I never even ran aocl-opt.exe directly. The only things you should need to directly use are aoc.exe and aocl.exe.
Not sure if this would work, but try reordering your path to match that of mine, which works without any problems.
