APaqu's avatar
APaqu
7 years ago
aoc: Quartus is not on the path!
I am trying to get aoc to run using quartus 18.1 and get this error on linux (RHEL 7.6).
Quartus and related tools are on my path.
Any ideas what I am missing?
[apaquette@yoda hello_world]$ aoc  device/hello_world.cl -o bin/hello_world.aocx
aoc: Is it installed on your system and quartus bin directory added to PATH environment variable?
[apaquette@yoda hello_world]$ which quartus
~/intelFPGA/18.1/quartus/bin/quartus
[apaquette@yoda hello_world]$ quartus_map -s
Info: *******************************************************************
Info: Running Quartus Prime Analysis & Synthesis
    Info: Version 18.1.0 Build 625 09/12/2018 SJ Standard Edition
    Info: Copyright (C) 2018  Intel Corporation. All rights reserved.
    Info: Your use of Intel Corporation's design tools, logic functions
    Info: and other software and tools, and its AMPP partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Intel Program License
    Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
    Info: the Intel FPGA IP License Agreement, or other applicable license
    Info: agreement, including, without limitation, that your use is for
    Info: the sole purpose of programming logic devices manufactured by
    Info: Intel and sold by Intel or its authorized distributors.  Please
    Info: refer to the applicable agreement for further details.
    Info: Processing started: Tue Jul 30 13:54:41 2019
Info: The Quartus Prime Shell supports all TCL commands in addition
Info: to Quartus Prime Tcl commands. All unrecognized commands are
Info: assumed to be external and are run using Tcl's "exec"
Info: command.
Info: - Type "exit" to exit.
Info: - Type "help" to view a list of Quartus Prime Tcl packages.
Info: - Type "help <package name>" to view a list of Tcl commands
Info:   available for the specified Quartus Prime Tcl package.
Info: - Type "help -tcl" to get an overview on Quartus Prime Tcl usages.
tcl> exit
[apaquette@yoda hello_world]$ echo $PATH
/home/apaquette/intelFPGA/18.1/hld/bin:/home/apaquette/intelFPGA/18.1/quartus/bin:/usr/lib64/qt-3.3/bin:/home/apaquette/perl5/bin:/opt/bwtk/2019.1/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/apaquette/.local/bin:/home/apaquette/bin
[apaquette@yoda hello_world]$ echo $LD_LIBRARY_PATH
/home/apaquette/intelFPGA/18.1/hld/board/a10_ref/linux64/lib:/home/apaquette/intelFPGA/18.1/hld/host/linux64/lib:/home/apaquette/intelFPGA/18.1/hld/linux64/lib:
[apaquette@yoda hello_world]$ echo $AOCL_BOARD_PACKAGE_ROOT
[apaquette@yoda hello_world]$ aoc -list-boards
Board list:
  a10gx
     Board Package: /home/apaquette/intelFPGA/18.1/hld/board/a10_ref
  a10gx_hostch
     Channels:      host_to_dev, dev_to_host
[apaquette@yoda hello_world]$ aoc -version
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 18.1.0 Build 625 Standard Edition
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    What is the output of echo $ALTERAOCLSDKROOT? Have you run init_opencl.sh script to set the AOCL user environment variables?
  • APaqu's avatar
    APaqu
    [apaquette@yoda hello_world]$ echo $ALTERAOCLSDKROOT
    [apaquette@yoda hello_world]$ echo $INTELFPGAOCLSDKROOT
  • APaqu's avatar
    APaqu
    yes
    apaquette@yoda hello_world]$ source $INTELFPGAOCLSDKROOT/init_opencl.sh
    INTELFPGAOCLSDKROOT is set to /home/apaquette/intelFPGA/18.1/hld. Using that.
    Will use $QUARTUS_ROOTDIR_OVERRIDE= /home/apaquette/intelFPGA/18.1/quartus  to find Quartus
    AOCL_BOARD_PACKAGE_ROOT is set to /home/apaquette/intelFPGA/18.1/hld/board/a10_ref. Using that.
    Adding /home/apaquette/intelFPGA/18.1/hld/bin to PATH
    Adding /home/apaquette/intelFPGA/18.1/hld/host/linux64/lib to LD_LIBRARY_PATH
    Adding /home/apaquette/intelFPGA/18.1/hld/board/a10_ref/linux64/lib to LD_LIBRARY_PATH
    KhaiChein_Y_Intel
    It seems like the path is pointing to the correct directory. Have you try to reinstall the software?
  • APaqu's avatar
    APaqu
    No, I have it installed on 2 different linux machines (Ubuntu and Redhat) without any luck. Someone mentioned that I couldn't run it on an Arria 10 anyway using Quartus Prime Standard (I don't have pro). I gave up and moved on to other hardware/tools for what I was trying to do.
    KhaiChein_Y_Intel
    Arria 10 is supported in Standard edition. Do you still need any help on this?
