9 years agoAOC issue: Assert failure at PickLocalMemConfig.cpp(1209)
Hello, I'm currently facing an error when trying to compile my openCL kernel: "Error: Assert failure at PickLocalMemConfig.cpp(1209)" It seems to be related with inferring local registers ...
9 years agoIt is not possible to know why compilation crashes happen because the compiler is closed and only Altera knows how it works. You should try the kernel on the latest version of AOC. If it works, it means Altera has already fixed the problem and you have no choice but to ask your board manufacturer to update their BSP. If not, you should open a service request with Altera directly and report the bug.
P.S. if you are using a Stratix V board and not an SoC board, it is quite likely that the latest version of AOC will still be compatible with your old BSP.
