9 years agoAOC Error while running hello world
Command used: aoc -v device/hello_world.cl -o bin/hello_world.aocx --board a10gx Output: aoc: First stage compilation completed successfully. Error: Peak virtual memory: 1036 megabytes ...
9 years agoFrom "Intel® FPGA SDK for OpenCLGetting Started Guide":
--- Quote Start --- Development system requirements: • You must have administrator privileges on the development system to install thenecessary packages and drivers. • The development system has at least 85 gigabytes (GB) of free disk space forsoftware installation. • the development system has at least 24 gb of ram. Tip: Refer to board vendor's documentation on the recommended system storagesize. --- Quote End --- Are you sure that your hardware requirement is correct?
