11 years ago
aoc device/fft1d.cl -o bin/fft1d.aocx --board s5phq_d8 (FAILED)
Hello, everyone
I used Board bittware s5-pcie-hq d5/d8 (http://www.bittware.com/products-services-fpga-cots-hardware/s5-pcie-hq), and operated it in OS : CentOS 6.6 , Software circumstance is Quartus 15.0
and I want to execute the example source code download from https://www.altera.com/support/support-resources/design-examples/design-software/opencl/fft-1d.html
But it failed every time.
on above site I found the Boards information as followed,
fft performance
[TH="class: header-left"]Boards[/TH]
[TH]GFLOPS[/TH]
nallatech pcie385-a7/d5 (http://www.nallatech.com/opencl-fpga-accelerator-cards.html)
81
then what's it exact meaning? Does it mean that If I have one of the bittware s5-pcie-hq d5/d8 (http://www.bittware.com/products-services-fpga-cots-hardware/s5-pcie-hq),
nallatech pcie385-a7/d5 (http://www.nallatech.com/opencl-fpga-accelerator-cards.html) boards , the example code could be compiled and executed successfully?
Or Does it mean that I should have all of the boards connected with my PC, then the fft1d.cl file can be compiled into fft1d.aocx successfully?
The hello_world example has been executed successfully, and the result could be expressed as following :
[root@hello_world]# aoc --list-boards
Board list:
s5phq_a7
s5phq_ab
s5phq_d5
s5phq_d8
[root@hello_world]# make run
./hello_world
Querying platform for info:
CL_PLATFORM_NAME = Altera SDK for OpenCL
CL_PLATFORM_VENDOR = Altera Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 15.0
Querying device for info:
CL_DEVICE_NAME = s5phq_d8 : S5PHQ
CL_DEVICE_VENDOR = BittWare Inc
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 15.0
CL_DRIVER_VERSION = 15.0
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 8589934592
CL_DEVICE_IMAGE_SUPPORT = false
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 2147483648
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Reprogramming device with handle 1
Kernel initialization is complete.
Launching the kernel...
Thread# 2: Hello from Altera's OpenCL Compiler!
Kernel execution is complete.
In my case , only hello_world example can be executed successfully, but when I tried to compile the others, its all failed.
vector addition (https://www.altera.com/support/support-resources/design-examples/design-software/opencl/vector-addition.html)
*Updated in 14.1
  • OpenCL API
  • Partition a large problem across multiple devices
  • OpenCL events and event profiling
  • Getting started
This simple design example demonstrates a basic vector addition OpenCL kernel and its corresponding host program.
fft (1d) (https://www.altera.com/support/support-resources/design-examples/design-software/opencl/fft-1d.html)
“Updated in 14.1”
  • Single-precision floating-point optimizations
  • Single work-item kernel
  • Performance
This design example demonstrates a high-performance 1D radix-4 complex fast Fourier transform (FFT) or inverse fast Fourier transform (IFFT) engine using OpenCL. This example takes advantage of the efficient sliding window data reuse pattern.
executed in kernel : aoc device/vector_add.cl -o bin/vector_add.aocx --board s5phq_d8
aoc device/fft1d.cl -o bin/fft1d.aocx --fpc --no-interleaving default --board s5phq_d8
Now I do need help! What can I do next?
Any advice will be welcome and appreciated!
Thanks in advance.
