9 years agoaoc cannot find valid licences file
Hello. I'm trying out compiling Altera OpenCL on a new workstation. After acquiring the license file and installing Quartus II and OpenCL SDK. I tried to compile some OpenCL. But aoc refuses to d...
9 years agoMake sure the "LM_LICENSE_FILE" path is correct in your bashrc. If you are using Quartus v17.0, but acquired your license before v17.0 was released, you might need to request a new license from Altera. We were using the same license all the way from v15.0, but v17.0 rejected those licenses, so we had to acquire new ones. Also if you are on the v17.0 branch, make sure you are using v17.0.2; the latest update claims to have fixed some issue with valid licenses being rejected.
