10 years agoAny Magic to Make *.qxp Partition File Work in Quartus Prime Pro v16.0+ (Spectra-Q)?
I'm working with Arria 10 and using Quartus Prime Pro v16.0+, which uses the Spectra-Q synthesis engine. An IP provider's design includes a *.qxp exported partition file that successfully compi...
10 years agoI'm pretty certain that won't work. .qxp files are part of the Incremental Compilation flow in Quartus Prime Standard, where Prime Pro is going to a new database and new underlying flow for incremental compilation. As for another method, it's possible the provider could become an IP partner with Altera, as they can encrypt their source and deliver it that way. (Probably overkill for what you're doing, but throwing it out as an option.)
