11 years agoanother SPI interface timing constraint question
This thread describes almost my exact situation: http://www.alteraforum.com/forum/showthread.php?t=48900 I have a SPI master state machine that runs at 96MHz (output of PLL from 24MHz exte...
11 years ago --- Quote Start --- Tested and working in hardware. Can't thank you enough for the help! --- Quote End --- You are most welcome! Cheers, Dave
conmemsr
5 years agoHi ,
I trying to set proper IO constraints for SPI Master where SPI_CLK_O and SPI_MOSI are generated by an internal clock and SPI_CLK_O is a divide by 4 generated with internal fast clock as source.
Can you re-post the solution or share the PDF with the timing analysis.
msr
