11 years agoanother SPI interface timing constraint question
This thread describes almost my exact situation: http://www.alteraforum.com/forum/showthread.php?t=48900 I have a SPI master state machine that runs at 96MHz (output of PLL from 24MHz exte...
11 years ago --- Quote Start --- I did some timing analysis on Quad SPI flash here: https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip The timing constraints files should be able to help you. Cheers, Dave --- Quote End --- Very generous, Dave - thank you! I scanned the pdf briefly and it looks very well written and matches what I'm doing. When I get a chance I'll update my constraints and post the results. Two generated clocks? I never would have figured that out. Best, Bob
