11 years agoanother SPI interface timing constraint question
This thread describes almost my exact situation: http://www.alteraforum.com/forum/showthread.php?t=48900 I have a SPI master state machine that runs at 96MHz (output of PLL from 24MHz exte...
11 years agoI did some timing analysis on Quad SPI flash here:
https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip The timing constraints files should be able to help you. Cheers, Dave- David322 years ago
I have pretty much the same question and would very much appreciate access to the files mentioned.
The links seem to be no longer valid however.
Could you please repost with updated links.
Thanks in advance.
David
