Altera_ForumHonored Contributor16 years agoanother question - Error message that is wrong? I have another error message I am getting: "Error: Text Design File syntax error: Text Design File contains "end of file" where "END" was expected" Except that when I double click the messag...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
