9 years agoAn issue about compiling the OpenCL to FPGA
Hi, I met an issue about compiling the OpenCL HelloWorld/Vector_add code to FPGA. Quartus Prime can offload the VHDL code into the FPGA board but the OpenCL SDK and compiler can not progra...
9 years agoSo they put the blame on Altera, that is convenient for them. I have been using the same version of Quartus (16.1.2) with another manufacturer's board and BSP and I have no problems whatsoever. Being able to program the FPGA does not prove their BSP is working correctly, it just shows that their PCI-E driver is working. I am afraid I have no other solutions for you. You can contact Altera instead and show them your compilation log and ask what is wrong, but they will likely tell you to go contact Terasic because this is most likely a problem with Terasic's BSP.
