11 years agoAltsyncram -read data
Hi, i have a problem to read data from an address ( i use the altsyncram block). For example i want to read the value 5 from the address 200. In the mif file i have fill with the number 5 , the space of address 200. I have also put pins in the altsyncram for the address and the data .In the waveform during the clock cycle which the read signal is 1, the result of the address is 200 when the clock goes from 0 to 1, but the data doesn't change. May i have to set a different value in fmax to the classic timing analyzer wizard or set a higher period or something else to change at the options?Generally, i am not an expert about the options ,quartus gives.
