i am using vesion 8.0 SP1, build 07/10/2008 SJ Full version.
I have tried the following things in my end and still have the issue:
A. Assigning pin location thru synthesis directive instead of thru pin planner:
input inclk0 /* synthesis chip_pin = "AA1" */; // input Clock
I got the same error.
B. Driving the PLL input thru altclkctrl in the following manner:
altclkctra pcst_altclkctrl_inst1 (
.inclk (inclk0),
.outclk (pll_clkin) );
pcst_sysclkpll pcst_sysclkpll_inst (
.areset ( PLL_RESET ),
.inclk0 ( pll_clkin ),
.c0 ( SYSCLK ),
.c1 ( CR4CLK ),
.locked ( PLL_LOCKED )
I got the following error:
Error: Clock input port inclk[0] of PLL "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Info: Input port INCLK[0] of node "pcst_sysclkpll:pcst_sysclkpll_inst|altpll:altpll_component|pcst_sysclkpll_altpll:auto_generated|pll1" is driven by altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|wire_clkctrl1_outclk which is OUTCLK output port of CLKCTRL type node altclkctra:pcst_altclkctrl_inst1|altclkctra_altclkctrl_nie:altclkctra_altclkctrl_nie_component|clkctrl1
eventhough it is driven by CLKCTRL node, i get the same error and dont understand why.
