10 years agoAltmult_add in MAX10
I am trying to use an embedded multiplier in MAX10M50 device. I am using Quatus II 15.1 When I double click on ALTMULT_ADD in the "IP Catalog" pane, I get "Save IP Variation" dialog and then Quartus saves cnx file (I select my project directory as a destination for the file). Once I press Enter the dialog closes but the Wizard doesn't open. For LPM_MULT the wizard works and I get files lpm.v and lpm.qip. Am I doing something wrong? Thank you, VitalyNo RepliesBe the first to reply
