altmemphy ip license problem
I need to modify an old project, developed with Quartus II 9.0 on a Stratix III, that contains a DDR2 controlled made using an altmemphy IP. So I installed the software, made the modifications and recomplied it. Unfortunately it is not more possible to generate a working programming file, because with the current Quartus II license file (dated august 2015), the license to compile this IP is not more present. Only a time-limited programming file is generated. So I have the right software, I have a working license, but I cannot use an IP whose license was previously included into the base software. Why?
I configured the license server with the old (expired) license file, and it was possible to compile and generate the programming file, but this cannot be a solution because we have floating licenses running on a server, that is used by many designers. I tried to run multiple services from the flexlm tool, connected to different IP ports. In this way I could connect to an alternate server port only when I am working on this old project. It works, but after some time, the altera license daemon stops with an error, because it detects another daemon running. I can understand why: if this would be possible, I could easily multiply my licenses, and this is not allowed. I cannot force the whole company to use an old license (having puchased a new one) file only because I need it... so my question is: is there a "legal" way to do this? regards Davide2 Replies
yes... buy another license is the most "legal" way.
No, it is not. Altera does not sell licenses for this IP. They discontinued the licensing for the altmemphy IP. I called the local support and they confirmed me this.
bye
