15 years ago --- Quote Start --- Hi, I am a new member of this forum and my English is terrible. I nomaly use the ALTLVDS_TX and ALTLVDS_RX with quartusII9.1, but now I have installed quartusII10.0 sp1 I can't do it. When I try to use the block, the mega wizard don't open, the progress bar run but after this don't happen nothing. Colud anyone help me please? By By --- Quote End --- Hi, did you try the recommended Altera workaround, which I posted in this thread ? To work around this issue make sure the regional settings on your machine is set to English (UK or USA). This will not affect keyboard mappings, but will affect the default number separators: 1) Open the Regional and Language Options menu from the Windows Control Panel. 2) In the “Standards and Formats” box, select “English (UK)” or “English (Untied States)” from the drop down list. 3) You should see the “.”’s change to “,” in the Number section of the samples window. Kind regards GPK
