15 years ago --- Quote Start --- kevin, are you using CIVGX? the issue is on page 16 of the 10.0 Release Notes: http://www.altera.com/literature/rn/rn_qts.pdf seems the Release Notes are a must read for this version --- Quote End --- That item in the release notes does seem to describe the symptoms I am seeing. However, I am using Cyclone III and Cyclone IV E, not Cyclone IV GX. Also, the described work around does not work. After selecting Stratix II GX and then clicking next the wizard freezes and the only thing I can do is close it. My current work around is to just use the mega wizard from 9.1sp2 to create the LVDS functions. The results seems to compile fine in 10.0.
