17 years ago --- Quote Start --- I seriously care about it, cause I have hardware connected to some I/O pins that may be instantly damaged when receiving illegal signal patterns. --- Quote End --- I see. You are using the weak pull-ups, not for the purpose of avoiding floating inputs on the FPGA, but also for providing a defined power-up output level. I assumed that in those applications where the power-up level is critical, an external pull-up or pull-down would be used, but I guess I was wrong.
