Altera_ForumHonored Contributor17 years agoAlternative to weak pull-up for I/O during configuration? Hello, I've got the following problem: I use a Cyclone II FPGA in a complex design. Some User I/Os are connected to npn transistors. The problem is, that during configuration thru an epc...Show More
Altera_ForumHonored Contributor17 years agoBus-hold hasn't a defined initial level, it would be unacceptable for many applications.
Recent Discussionsagilex7 ram back-annotationFIR IP configured for InterpolationSSLC Login Issue – "You need to enroll" loop after OTP verificationA5EG013BB18A OPN is visible in Quartus but not listed in Program File Generatoraltera scfifo ip with power-up initial value
