17 years agoIn unconfigured state, the device didn't yet receive any configuration data. How should Quartus be able to change the device behaviour then? the weak pull-up mechanism is hardwired in fpga silicon only.
An external pull-down resistor is a simple and reliable method to achieve the required behaviour. The weak pull-up resistor range is given in device manual (10 k minimum for most devices), it's easy to calculate a suitable pull-down resistor dimensioning.
