10 years agoAltera SDK license for OpenCL
Hi All,
I am getting an Eroor for aoc command. Error : aoc : cant find valid License for Altera SDK for OpenCL. Please note: I alreday gave all Licenses. What to do now? How can I check wether, I have my licenses executed or not?7 Replies
Did you set the LM_LICENCE_PATH environment variable?
Please check the name in the documentation, I don't know if I have the exact name. - Altera_Forum
--- Quote Start --- Did you set the LM_LICENCE_PATH environment variable? Please check the name in the documentation, I don't know if I have the exact name. --- Quote End --- Hi. Yes, I appiled environment variable for Licence. But still I am getting an error. Could you please let me know any command to verify Licences? I have one more question: for my case source ./init_opencl.sh command is showing error. "Source command is not found". Could you let me know why I am not able to run this command? - Altera_Forum
I don't know about any command, but you can check in Quartus. Tools->License setup
I check in Quartus. Licences are already there.
Well, I am using floating licences and same licence I gave path to environment variable. Now what can I do? Just wanted to make sure that Licences which I am using for Quartus, can I use same Licence for OpenCL SDK? - Altera_Forum
It is the same license file, but, as far as I know, you'll need a license for the OpenCL SDK as well. That license is written into the license file. But maybe you might look into the Altera documentation: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf page 2-5
I know that I have Licence for Quartus but I am not sure that I have valid licence for OpenCL SDK. Now how can I verify OpenCL SDK Licence without Quartus? What I understand till date is : I need another Licence for OpenCL SDK. Am I right? - Altera_Forum
Jup, that's correct. You can open the license file in a text editor and see if you can find mentions of the OpenCL SDK.
