12 years agoAltera SDK 12.0
Hi, Does anyone know where I can get the Altera OpenCL SDK version 12.0. I am using a Stratix IV FPGA and it is not supported by Altera 12.1sp or 13.0. Regards.
I would take a look at the 13.0 SP1 version, there were a couple of bug fixes. Probably the easiest way would be to install the newer tools on a different machine so that you can get at the designs that come with it. Note that the way that you build the kernel is different starting in 13.0 so don't reference that part of the new code because it will not work in 12.1 SP1
Also when you installed the driver were any errors reported? If there is a problem you should see a yellow "!" show up above the device which means the device was found but that there was a problem.
